Model T Racing/Speedster Engine *SOLD*
Topic author - Posts: 11
- First Name: Jake
- Last Name: Knapp
- * REQUIRED* Type and Year of Model Ts owned: 1927 Speedster
I am selling my T racing engine that I was building for a speedster/hill climber. Unfortunately I will not be able to finish my project. This is a 26/27 block with all the work done. Insert main bearings and rod bearings. Model A counterbalanced crankshaft and Model A camshaft. Bored out with Buick pistons installed. Hard valve seats. 1.7" intakes, 1.6" Exhaust. Adjustable lifters. As you can see, intake ports were divided so that each cylinder has its own intake port. Intake ports have been molded and shaped with a special epoxy (common practice in drag racing engines). I have flanges that bolt to the block for building intake manifold and exhaust header. Rebuilt transmission with kevlar lined bands. Dan McEahern timing gear. Billet main caps. Aluminum head clearanced for the big valves and new solid copper head gasket. Hogs head and four dipper pan with external oiler kit. Pretty cool set up. I know its a lot but do some research and see what it costs to build just a regular T engine. Lots invested in this thing. Asking $5000 OBO. I need to get it out of the shop.
- First Name: Jake
- Last Name: Knapp
- Last Name: Chaffin
Re: Model T Racing/Speedster Engine
That cylinder head is a super hard piece to find. Don't believe those are available any longer.
- First Name: Joe
- Last Name: Bell
I thought the same thing on the head!
- First Name: Jake
- Last Name: Knapp
Looks like I've got it sold. Have a person coming tomorrow to check it out/most likely buy it. I will bump back to the top if the deal falls through.
Thanks!
Thanks!
- First Name: Joseph
- Last Name: Andulics
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1926 Truck, 1927 Roadster GOW, RAJO Sprint car
Lot of engine for splash oiling, or am I missing something? Otherwise looks awesome. Just my humble opinion
- First Name: David
- Last Name: Greenlees
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T racing car, 1924 Model T Depot Hack with original York #803 body.
Mark, Do you know the name of the person or company that cast and machined this head?Mark Chaffin wrote: ↑Sat Mar 11, 2023 6:05 pmThat cylinder head is a super hard piece to find. Don't believe those are available any longer.
No sir. Been many years ago.
I do know who currently has the patterns and I am trying to aquire them.
- Last Name: Hatch
Which Buick pistons are those? Thanks Dan
