Strobospark
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Strobospark
Post by BUSHMIKE » Sun Mar 12, 2023 10:03 am
I dont want to start any discussion on its merits or lack off! I just want to come up with a set of instructions for the use and coil tuning using the Strobospark. I am only assuming that it was sold with a printed instruction sheet?
Last Name: Wrenn
Re: Strobospark
Post by TWrenn » Sun Mar 12, 2023 10:06 am
Here Mike. Quick! Try this before all the controversy starts again! :lol: :lol: :lol: Feelilng a little devilish :twisted: this morning I guess! ha ha. Hope this helps.
https://www.youtube.com/watch?v=zfXVIlIO_4Q
Chris Barker
First Name: Chris
Last Name: Barker
Re: Strobospark
Post by Chris Barker » Sun Mar 12, 2023 10:54 am
The video is helpful, but first you need to check the capacitor:
Hold the points open, Meter set to Cap Leak, press Test - should be zero or close
Hold the points open, Meter set to Cap Value, press Test - should be 4.7, but 2 to 10 will work
Only then go to Coil Amps, medium magneto, press Test and you should get 3 single steady sparks, and about 1.3A
In summary:
Lower point root end bend affects current
Cushion point tension affects single/double spark - you need a tool https://www.modeltford.com/item/5008CST.aspx
Adjusting nut affects everything!
It's an art that you will pick up. When it works on medium magneto, check high and low.
The cushion point travel should be about 0.005" - and all 4 coils should be similar
When the coil is at rest, the lower point must push the cushion spring up off its rivet head to touch the top piece. See photo
When the lower point is held down, the cushion spring must rest against its tiny rivet head. See photo
The points gap doesn't matter, within reason, as long as you have 3 single sparks and about 1.3A (1.1A to 1.4A)
When it's right, add a locknut to the adjuster to stop you or anyone else fiddling with it!!
BUSHMIKE
Last Name: Cushway
Re: Strobospark
Post by BUSHMIKE » Sun Mar 12, 2023 11:06 am
Tim,
I watched that prior to posting. The video does show a couple points, which helps. I would still love to see a set of printed instructions. It doesn’t sound like there will ever be Strobo Spark collectors group so SN 0012 is a moot point :roll: The coil that came with the unit apparently needs work!
BUSHMIKE
Last Name: Cushway
Re: Strobospark
Post by BUSHMIKE » Sun Mar 12, 2023 11:08 am
Chris,
That is fantastic info!
Thank you.
Art M
First Name: Art
Last Name: Mirtes
Re: Strobospark
Post by Art M » Sun Mar 12, 2023 11:49 am
Mike,
If you cannot find a strobotach, try reading the topic in this site, A New DIY electronic coil tester. It is very interesting and informative. Let's us know your results.
Art Mirtes
Last Name: Tannehill
Board Member Since: 2002
Re: Strobospark
Post by JTT3 » Sun Mar 12, 2023 3:46 pm
Copied for your reference from Funprojects aka Mr John Regan.
Re: Strobospark
Post by speedytinc » Sun Mar 12, 2023 4:00 pm
Whats with page 2? Do you need a real ID to operate it?? :o :o
Edit; Page 2 of 3 was removed.
Re: Strobospark
Post by JTT3 » Sun Mar 12, 2023 4:13 pm
John it’s what happens when you’re to cheap to buy new printer paper. Ha
BUSHMIKE
Last Name: Cushway
Re: Strobospark
Post by BUSHMIKE » Sun Mar 12, 2023 4:54 pm
Many thanx John! I thought someone here would have a paper copy.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Strobospark
Post by BE_ZERO_BE » Sun Mar 12, 2023 9:11 pm
Here is the full PDF.
STROB-O-SPARK CT-1.pdf
(1.1 MiB) Downloaded 165 times
Respectfully Submitted,
Be_Zero_Be
