WTB: Stevens Sea Lion and Arbors
Topic author - Posts: 25
- First Name: Simon
- Last Name: Bayley
- * REQUIRED* Type and Year of Model Ts owned: 1925 Ford tourer
A fellow T Ford hobbiest recently purchased this Stevens Conrod Alignment Fixture. However it is missing the sea lion and arbours.
Does anyone by chance have a sea lion, arbours or both spare?
Thanks Simon
Thanks Simon
- Last Name: Prus
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 torpedo, 1914 touring, 1919speedster, 1921 touring, 1922 touring 1925TTsemi, 1926 pickup, 1926 roadster
- Board Member Since: 2004
Re: WTB: Stevens Sea Lion and Arbors
I have the entire set up sale. Only 600.00 plus postage
Kevin Prus. I would sell the extra lions foot for 300.00. Kprus@zoominternet.net
Three30seven74seven one 30
- First Name: Simon
- Last Name: Bayley
Thanks for your reply. I have sent you a message via email.
- First Name: Simon
- Last Name: Bayley
Still looking if you have one
- First Name: Trent
- Last Name: Boggess
You really need just the Sea Lion, mandrels can be made. The original Stevens mandrels were made from 1-3/8 diameter steel bar, then turned down to different sizes to fit different makes of cars. Only one was made for the Model T and it came in standard size only.
If you are actually going to use the Stevens jig to check the alignment of Model T rods, you will want to make several undersize mandrels. In addition to a standard 1.250, I made two addition mandrels .010” and .020” smaller in diameter for the two most frequently used sizes.
Respectfully submitted,
Trent Boggess
Trent Boggess
- First Name: Simon
- Last Name: Bayley
Hi Trent,
Thanks for the valuable advice - you wouldn’t by any chance have a spare sealion?
Regards Simon
Regards Simon
You can avoid making multiple mandrels for different sized/makes of rods by milling the end of a mandrel square, and adding a slight bevel on the corners. our Repco/Warren and Brown rod fixtures come with just three square mandrels. These three will cater for big diesel engine rods, down the the small model T rods.
- First Name: Simon
- Last Name: Bayley
Thanks Allen for the info
Here I thought this is what you were looking for!
Learn something new every day...
