What does this fit????
Last Name: Hatch
Post by Dan Hatch » Sat Mar 25, 2023 11:53 am
Anyone know what this ring gear and pinion fit.
11 tooth pinion 42 on ring gear. Shaft in pinion is tapered like a T. Looks to be same size as T. Any info would welcome. Thanks Dan
Re: What does this fit????
Post by Mark Gregush » Sat Mar 25, 2023 12:45 pm
There is the possibility it is very early Model A before the changes to how the pinion was made and assembled. Not later V8/B enclosed driveshaft.
You might try posting it on AACA what is it section or over on Fordbarn.com in the Model A section.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Mar 27, 2023 12:37 am
Chevrolet used a ring & pinion very much like that. Have seen them sold as model T. And may be adaptable to model T?
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon Mar 27, 2023 5:13 am
26-28 Chevrolet I believe.
