Ruckstell Axle
Barteldes
First Name: Bill
Last Name: Barteldes
* REQUIRED* Type and Year of Model Ts owned: 1924 Coup
Ruckstell Axle
Post by Barteldes » Wed Mar 29, 2023 5:55 pm
Does anyone know how i get my hands on a Ruckstell Axle? I suppose you are all laughing right about now.
BIll B
No matter how you shake and dance the last few drops go down your pants.
Last Name: Strange
Re: Ruckstell Axle
Post by CudaMan » Wed Mar 29, 2023 6:05 pm
Not at all, check the classifieds or contact Glen or Mark Chaffin at Chaffin's garage. :)
https://www.chaffinsgarage.com/
By the way, IMO there's no such thing as a cheap Ruckstell. Any money you may think you save on the initial purchase will be offset by the cost and labor of replacing worn out parts.
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Re: Ruckstell Axle
Post by Mike Lebsack-Iowa » Wed Mar 29, 2023 6:10 pm
Good quality rebuilt Ruckstell axles are out there but they are generally pricey depending upon the extent of the rebuild. Original in rebuilt Ruckstell axles almost always need parts, often exceeding $1000 between the drive shaft, pinion, shift lock, axles, internals, and then of course it takes time and knowledge to get the work done right. Thank goodness Chaffins and others make good replacement parts.
dinosbunny
First Name: dino
Last Name: marinelli
Re: Ruckstell Axle
Post by dinosbunny » Thu Mar 30, 2023 2:34 pm
I have nothing to do with this ad
Model T Ford Classifieds on facebook.
Rob Reif · 45m ·
Selling a complete Ruckstell differential, with the shifter assembly, for a Ford Model T. I also have an assortment of parts that can be used to build up a second Ruckstell.
The complete assembly, in the attached photo, was under my 26 Roadster and is in excellent condition. Thrust washers, gaskets and new bearings should be all that's needed.
Most if the parts on the 2nd photo are in decent condition and could be used to build up a second Ruckstell.
I prefer to sell the entire lot, which is a great deal for someone willing build two and sell one.
$1750 for both, pretty good deal
First Name: craig
Last Name: leach
Re: Ruckstell Axle
Post by Craig Leach » Fri Mar 31, 2023 1:36 am
Hi Bill,
I know this will never happen again, 5 years ago I picked up a Ruckstell, engine & frame at a metal recycling place on a tip from a friend for
$350 the engine was seazed but the Trans. yeilded many good parts. The Ruckstell was in impecable condition and was up & running for a
total of $500. And still had a good Trans. that went in another engine set up. I concider this a 1 in a 1000 deal but now I have know idea why
I didnt have one before.
Re: Ruckstell Axle
Post by Original Smith » Fri Mar 31, 2023 11:42 am
Please state the year you are looking for!
Barteldes
First Name: Bill
Re: Ruckstell Axle
Post by Barteldes » Fri Mar 31, 2023 12:37 pm
1924 Coupe
BIll B
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Ruckstell Axle
Post by ThreePedalTapDancer » Mon Apr 03, 2023 12:26 pm
Re: Ruckstell Axle
Post by Mark Gregush » Mon Apr 03, 2023 1:42 pm
Add wanted to your title using the pencil. :)
Last Name: Tannehill
Re: Ruckstell Axle
Post by JTT3 » Mon Apr 03, 2023 1:52 pm
That’s a real deal, it is a small drum style & has the long nose shifter plus less than 2 hours from you. Let us know if you decide to get it. I might have to if you don’t. Best John
