WTB. Exhaust manifold for AKRON-HAL overhead
civinwt
First Name: Bruce
Last Name: Hopkins
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 20TT 1Ton, 27 Runabout
Post by civinwt » Tue Apr 11, 2023 12:06 pm
I am needing an exhaust manifold for an AKRON-HAL overhead set up that uses the tubes and ball bearings to actuate the valves. Any leads greatly appreciated.
Thank you, Bruce
Re: WTB. Exhaust manifold for AKRON-HAL overhead
Post by Mark Gregush » Tue Apr 11, 2023 12:10 pm
Have you checked with Kevin? (Guessing you have but putting it out there anyway)
viewtopic.php?t=11172
I have only seen one of these units in the wild and that was over 20 years ago and don't recall if that one had the manifolds.
civinwt
First Name: Bruce
Last Name: Hopkins
Post by civinwt » Tue Apr 11, 2023 1:34 pm
Mark:
thank you for the suggestion., I have just e-mailed Kevin.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Apr 11, 2023 8:09 pm
Hey there Bruce,
If you had asked me last year, I probably would have sold mine. Bout that time I even offered to loan it to the Speedway Museum
I have since decided to use mine, but did make up some header flanges that I am willing to part with. They are 1/2” thick stainless steel
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Apr 11, 2023 11:53 pm
Just in case, here is a pic of the manifold Bruce is looking for…
Please disregard all the shiny stuff😉
civinwt
First Name: Bruce
Last Name: Hopkins
Post by civinwt » Wed Apr 12, 2023 10:03 am
Kevin, thank you for the offer of the flanges, and thank you for the picture of desired manifold.
When I acquired the rocker assembly from you, you included a pair of the pictured exhaust flanges.
I too want to run the exhaust under the frame so as to not modify the torpedo hood in any way.
