Datsun B-210 series Oil pump
Ericgj85
Topic author - Posts: 35
- First Name: Eric
- Last Name: Johnson
- * REQUIRED* Type and Year of Model Ts owned: 1926 speedster
Looking for the adaptor if anyone has one laying around.
Thanks,
Eric
Thanks,
Eric
- First Name: Henry
- Last Name: Lee
Re: Datsun B-210 series Oil pump
My local scrap dealer had about 25 about 1 year ago I delivered. I believe my cousin in China has converted them into tv mounting brackets at Walmart.
Ericgj85
- First Name: Eric
"Henry K. Lee"
I knew you would comment ! I wish you would have kept some all of the info I could find would lead me back to that post about scrapping them!
Les Schubert
- First Name: Les
- Last Name: Schubert
I see the pump is available on Rockauto. “Inventing” the bracket isn’t that difficult.
ModelTWoods
- First Name: Terry
- Last Name: Woods
He DID say he was looking for an adapter; not the pump. He evidently has, or has access to, a pump. Yes, the adapter is not complex, but if you have one, it is a lot easier to bolt one on, than have to make or machine one. Not everyone has a machine shop or the skills.
blauvelt
- First Name: Douglas
- Last Name: Ogden
Dan McEachern probably has some laying around.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Actually, i do not- never made any- tried to buy some pumps for another project, but that did not go so well....... Kirk Wright made some up for sale many years ago but ...........
Les Schubert
- First Name: Les
I have one of Kirk Wright’s. I did a bit of “tweaking” and plan to run it finally in the next couple of weeks.
You can see it here!
Kevin Pharis
- Last Name: Pharis
I just took mine off my speedster engine to install my alternator/oil pump drive… but my dad quickly claimed it for himself.
I do suggest seeking out an iron Melling pump rather than the lower precision aluminum alternatives. The iron pump I removed had very little noticeable wear after 10+ years. I am happy to make up a sketch of the adapter I removed if this helps
Ericgj85
- First Name: Eric
Okay Kevin if you could email a picture / sketch that would be a good start ! Email is ericgj85@aol.com
Shannon_in_Texas
- First Name: Shannon
- Last Name: Helm
Kevin, I (and I am sure others as well) would appreciate it if you would post that information here also. Thank you for sharing your ongoing OHV build-up on your own thread— enjoy seeing your amazing skills!
Harry Lillo
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
There was a guy from the Pacific NW selling the adapters at the Spokane swap meet last July.
He was machining them himself.
I bought one from him.
Our Washington or Oregon friends may know who he is?
Harry
Harry
Mikes 1912
- First Name: Lester
- Last Name: Husted
- * REQUIRED* Type and Year of Model Ts owned: 20
The cost of the pump is out of site. The last ones I bought was $260. If you can beat that price let us know where and how much.
Les Schubert
- First Name: Les
I just checked Rockauto. The aluminum one is $65.00 and the Melling iron one is $189.00. And that’s Canadian $
Kevin Pharis
- Last Name: Pharis
Here a quick look at what I made all those years ago…
Rough material dimension is 3.5” x 3.5” x 2.0”. Could probably take an inch off the length as the “snout” isn’t necessary. When I made this, I wanted to add a ball bearing to take the radial gear load but never did. After all these years the pump is in good shape, so bearing not needed. A simple register into the generator bracket will do
Dan McEachern
- First Name: DAN
If someone is going to do this, I'm machining generator gear blanks as I type this and could make some with a .490" bore to fit the Datsun pump shaft.
Just stirring the pot a bit................
RichJ
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
I have a block thatis someones unfinished project from many years ago It has a datsun pump bolted on it
I'm not able to get to it for about a week,to get pictures. It could be in Luray if intrested! Rich 561 262 0393
ModelTWoods
- First Name: Terry
- Last Name: Woods
Dan, I'll take one. It will keep me from having to put a brass bushing in a T generator gear.Dan McEachern wrote: ↑Wed Apr 12, 2023 7:34 pmIf someone is going to do this, I'm machining generator gear blanks as I type this and could make some with a .490" bore to fit the Datsun pump shaft.
Dan McEachern
- First Name: DAN
Be aware if you are purchasing a Melling pump- the Melling #M90 Nissan B-210 pump does not include the input shaft or the gerotor. The correct part number to purchase is the # M90A and is a complete pump. Just FYI.
Les Schubert
- First Name: Les
Looking at the pictures of the two versions of the B210 pump offered on Rockauto they certainly appear to be complete.
