Explosion Whistle Vacuum Question
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Fri Apr 14, 2023 9:26 am
I know there is some controversy regarding the use of combustion chamber or spark plug mounted explosion whistles, but does anyone know if they work off of intake vacuum? Maybe a silly question, but as much as I like "bells and whistles" those things are expensive and I'd rather hook one up to an intake manifold than the combustion chamber if that's possible.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Re: Explosion Whistle Vacuum Question
Post by BRENT in 10-uh-C » Fri Apr 14, 2023 9:34 am
Two different design configurations. The explosion whistle has an orifice that a blast of air travels thru to make the whistle sound. They will not work off of vacuum. Most whistle vacuum style wolf whistles use a small fan that uses vacuum to rotate the fan. This creates the shrill noise that when controlled by the valve creates the 'wolf whistle' sound. This type whistle will not work on compressed air.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Fri Apr 14, 2023 9:44 am
Thank you Brent, that is exactly what I needed to know.
Last Name: House
Post by George House » Fri Apr 14, 2023 10:53 am
DO NOT install a combustion chamber explosion ‘whistle’ unless you desire to join the Two Piece Crankshaft Club...
Don’t ask me how I know 😞
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Fri Apr 14, 2023 3:04 pm
"Modern" wolf whistles may be opereated via a vacuum or via pressure.
It's a matter of which direction the rotor is installed.
Don't know if "vintage" wolf whistles have the above option.
wolf whistle.png (342.6 KiB) Viewed 1155 times
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Apr 14, 2023 3:48 pm
I had an explosion whistle once, nothing but problems.
Post by speedytinc » Fri Apr 14, 2023 4:35 pm
I tried one once. Motor ran rough. I know others that run them with no problems.
