According oil level indicator.
Post by Allan » Mon Apr 17, 2023 7:03 am
Can anybody post photos of this unit showing the fitting which threads into the pan, and to which this barrel is fitted?
I need to make 6 of them, so I might as well make them as they were made originally, rather than just making my own fitting to do the job.
Re: According oil level indicator.
Post by Scott_Conger » Mon Apr 17, 2023 10:24 am
Alan
rather than type a bunch of words, here's what you're looking for (and note the stabilizing bracket): https://www.mtfca.com/discus/messages/1 ... 1298732304
Post by TXGOAT2 » Mon Apr 17, 2023 10:46 am
I'd use a heavy pipe nipple there. The standard ones are very thin at the thread roots.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Mon Apr 17, 2023 12:55 pm
Lots of folks like to comment about the risk of the little sight glass gauge that I use breaking off it sure is a good comment that Scott posted about using a substantial mounting bracket to support all that weight on such a small nipple!
RDR, Ralph Ricks always posted about his use if a sheet metal screw inserted into the nipple to prevent quick loss of oil in case it breaks off. If sized just right the level could read ok but the open flow would be in drips?..
1912 Torpedo Roadster
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Mon Apr 17, 2023 3:32 pm
Other oil level accessories can be seen in the gallery section:
https://mtfca.com/phpBB3/app.php/galler ... ?sk=n&sd=a
Post by Allan » Mon Apr 17, 2023 6:43 pm
That's the ticket Scott. I was averse to using a brass fitting, given the weight of these devices. The wrap round support bracket makes good sense too. Odd that it does not appear in the advertisement. If I have to make those too, the time taken will add up.
