Stamped logo
Topic author - Posts: 2039
- First Name: craig
- Last Name: leach
Stamped logo
I was thinking some one asked about this logo a while back. Anyone have knowlege of it. I found it on a small brake drum.
Thanks .
BUSHMIKE
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Re: Stamped logo
Craig,
Was it me you are thinking of? I asked about this logo on my TT frame a while back.
- First Name: craig
- Last Name: leach
Re: Stamped logo
Hi Mike,
It could have been, but was thinking it was the same logo?? Thanks.
Re: Stamped logo
The frame marking is Parrish and Bingham. Ford supplier.
That other mark appears as Transue Williams, another supplier.
- First Name: craig
- Last Name: leach
Re: Stamped logo
Thanks Dan,
Re: Stamped logo
On our Canadian sourced cars the Transue Williams mark appears as a capital T superimposed over the W. This mark i have only found on forged parts, an so it is raised.
Re: Stamped logo
Craig Leach wrote: ↑Tue Apr 18, 2023 9:29 pmI was thinking some one asked about this logo a while back. Anyone have knowlege of it. I found it on a small brake drum.stamped logo.jpg
Thanks .
May not be Transue Williams. That same mark is seen on tools too, like this hub cap wrench, since your rear hub brake drum is a steel stamping, like the flat hub cap wrench, could be this mark in a triangle is Weston Mott. They were a stamping concern.
- First Name: craig
- Last Name: leach
Re: Stamped logo
Thanks guys,
Looks like it most likely is a O.E.M. part. I thought it might be a after market because it doesn't look like it has any wear to speak of.
