I did my wheels today
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sun May 07, 2023 7:47 pm
At long last I respoked my wheels today. It went pretty smoothly. I need to peen the nuts and do a little paint touch up. The jig I made for drilling the holes straight worked perfectly.
I am sure that a set done by a professional would be nicer, but I am proud of them. Once they go back on, and I adjust the brakes, my 22 will be back on the road. I did the job in the family room as I can hardly get around the shop with the 22 up on jacks.
By the way, is there a recommended torque for the flange bolts?
The jig was a pice of scrap plate with a 3/4 in bolt bored through with a 3/8 hole on the lathe.
All the bits ready to go (still needed some carpet on the press).
The rears
The rears
The first one in progress
The fronts
The fronts
Reno Speedster
First Name: Morgan
Re: I did my wheels today
Post by Reno Speedster » Sun May 07, 2023 7:55 pm
Another angle of the drilling jig. It was held on by a 7 inch long 1/2 bolt through the hub.
Last Name: Strange
Post by CudaMan » Sun May 07, 2023 8:06 pm
Congratulations, nice work! :)
Post by Rich Eagle » Sun May 07, 2023 10:12 pm
Thanks for stepping us through it. I always learn from these things.
I suppose you are now a spokesman. :D
It's always nice to see others work.
Post by Allan » Mon May 08, 2023 1:41 am
The nuts should be tight, but not enough to distort the flange plate. Be prepared to tighten and re-peen them a couple of times more, once they have been run for a while. Nice work. Don't you just love it when something you have never done before turns out so nicely!
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue May 09, 2023 4:34 pm
My opinion and calculations show that the torque should be 40 ft lb based on wood crush strength, nut friction, clamp area, and size of bolt. The threads and nut face must be clean and dry. No lubricant
Other wise, follow previous tightening procedures
Art Mirtes
