WTB gas headlight mounting brackets
mklooksup
Topic author - Posts: 100
- First Name: manny
- Last Name: Kourounis
- * REQUIRED* Type and Year of Model Ts owned: 1915 pickup 1915 Delivery van 1925 Fordor at Lillekers 1924 Tudor
- Board Member Since: 2012
I have a set of brass headlights that need mounting brackets hook type. I have called all the suppliers and none have any at this time. I would take any condition at this point. Thanks manny
Re: WTB Headlight mounting hooks
Lack of replies could just come down to we don't know what it is that you are looking for. Do you mean the casting on either side that the lamp is mounted to forks with? Do mean something else? If you are asking about gas headlights we would need to know what brand of gas headlights they are, that is going to make a difference. We are going to need more information for anyone to help. Seems like you are working on a 26/27, so brass lamps would be throwing us a curve.
Are you planning to mount them on a speedster build?
Looking for 1,2,3 or ?
- Attachments
- headlight.png (75.27 KiB) Viewed 1662 times
mklooksup
- First Name: manny
Mick, I need fork marked # 2 in your diagram. Its for a early 1915. the headlights i have are THE E AND J MFG. CO. model 466
thanks
- Last Name: Tannehill
- Board Member Since: 2002
So you’re building a speedster on a fifteen style T.
Here is a link to one of the vendors it shows the steel & polished brass style of reproductions.
https://www.modeltford.com/pl.aspx?t=s& ... rks&page=1
You might want to click on the pencil thing and edit your title and change it to gas headlight forks.
mklooksup
- First Name: manny
Not building a speedsterJTT3 wrote: ↑Tue May 09, 2023 10:57 pmSo you’re building a speedster on a fifteen style T.
Lang's and Schneiders out of stock
mklooksup
- First Name: manny
thank you for your advice. I'm not building a speedster its for a 1914 15 delivery van built by Dave Currier in MaineMark Gregush wrote: ↑Mon May 08, 2023 1:58 amLack of replies could just come down to we don't know what it is that you are looking for. Do you mean the casting on either side that the lamp is mounted to forks with? Do mean something else? If you are asking about gas headlights we would need to know what brand of gas headlights they are, that is going to make a difference. We are going to need more information for anyone to help. Seems like you are working on a 26/27, so brass lamps would be throwing us a curve.
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
Re: WTB gas headlight mounting brackets
just sent you a e mail, Bob
