Model T Racer
1932 V8
Last Name: Buegeleisen
* REQUIRED* Type and Year of Model Ts owned: 1922 Speedster
Model T Racer
Post by 1932 V8 » Fri May 12, 2023 10:47 pm
Hello all, I have been a stalker of the Model T forums for a while. I signed back up as of last week because I bought a Model T Racer or Speedster depending on who you talk to.. My plan is to make it street legal so I need tires, headlights, a tail light, and get it licensed. That should be fairly easy but I will take my time and do it right. Headlights can make or break a car looks wise so they need to be right. I also want a small windscreen for the driver.. Lastly the yellow needs to go... I am not a fan of it.
I really like the car. It is very comfortable to sit in and has a 3 speed Muncie transmission, which I believe is similar to a Warford, so it should keep up with slow traffic .. The Winfield SR carburetor is in need of a rebuild which is easy enough except for parts.. I have a couple of gaskets and I can make some as well but I need a new diaphragm. I found one place that has a complete kit with diaphragm for $185.00. That seems a tad high but what do I know. I figured I would ask here first to see if anyone knows of any other options out there before I spend $185.00 .
Apparently this car was built in the 90's. From what I read the builder found a set of original Phelps wheels and built the car around them. Sounds fun..
Thank you for any help and input, Mike
Re: Model T Racer
Post by RajoRacer » Fri May 12, 2023 10:53 pm
Yowza !!! Nice looking ride !
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Re: Model T Racer
Post by Shannon_in_Texas » Fri May 12, 2023 11:12 pm
Maybe a Brooklands-style windscreen or similar would give the look you want. For headlights, you could make mounts from cut-down front fender brackets and use black-era headlights and they would be easily removable for when you want to go racing!
Like this (may be cheaper elsewhere):
https://mossmotors.com/224-100-racing-s ... n=shopping
Re: Model T Racer
Post by Wayne Sheldon » Sat May 13, 2023 4:27 am
Headlamps, and a lot of other things, are of course up to you. Personally, I like open wheels, no windshields, no headlamps on "racing" cars. Whether a T speedster is a "racing car" or not is largely a matter of semantics and opinion. However, to be thought of as a "racing car" it should have some amount of "go" beyond just the looks. It does not necessarily have to have overhead valves, although that does help. A lot of local fair circuits seriously raced flatheads!
You should decide what era you want the car to represent. If the car is registered as a pre1920ish, you may not be required to have headlamps.
I have had and sold five different model T speedsters. Only one of which I considered to be a racing car! It was registered as a 1919 (the base year of the chassis. But "as sat" it represented about 1926 with engine and chassis modifications (era original) to enhance performance. Although it had a flathead, the block was an original era heavily modified block with the largest valves and ports that could be stuffed into a model T block!
As a 1919, it was not required to have headlamps!
All the others had basically stock engines, some with overdrive transmissions and just a little extra to handle highway speeds. But they were all great fun!
You have a great looking car there! I hope to see you on the open highway some day.
Susanne
First Name: Susanne
Last Name: Rohner
Re: Model T Racer
Post by Susanne » Sat May 13, 2023 7:21 am
Yowza!! What a pretty car!!!
Headlight-wise, you're up in the air with what to do... it looks like you could run a set of stock headlight mounts, if you can find the forked ones that opens up a lot of possibilities. The taillight(s) / brake light(s) are easy... hang under the body. As to a windshield, I would be almost tempted to run something like what they do on Morgans, only because I don't like getting a face full of rain and bugs... The cool thing is you can rig mounting points to remove the parts for all out racing, or put them on for endurance runs, tours, etc...
IF you have to get it inspected for plates, It kind of depends on what the CHP officer doing the inspection says about lights, fenders, windshield, etc... Some of them are pretty cool, some ccan be real pieces of... um... work. If it already has plates, then you're pretty much golden.
Either way - I'm pretty jealous. The SCVMTFC's endurance run is next month, so your timing is excellent... :D :D :D
Re: Model T Racer
Post by Jerry VanOoteghem » Sat May 13, 2023 7:30 am
Very nice! Let's have a look under the hood!!!
AndyClary
First Name: Andrew
Last Name: Clary
Re: Model T Racer
Post by AndyClary » Sat May 13, 2023 9:50 am
Awesome looking speedster Mike. Can’t wait to see it in person. Now the pressure is really on to finish the Mercury.
Andy
1932 V8
Re: Model T Racer
Post by 1932 V8 » Sat May 13, 2023 10:42 am
Here is the engine
First Name: craig
Last Name: leach
Re: Model T Racer
Post by Craig Leach » Sat May 13, 2023 12:02 pm
Hi Mike,
Super nice racer, I have pics of it in my speedster ideas file. I realy like the body on it. You have two speedster runs coming up in CA. Santa Clara
I think is in June, super cool event & San Diego in October. Also a great event. I try to never miss San diego and hope to make it to Santa Clara a
couple more times. Next April Sun Country Model T club will have a speedster run in Arizona also. Congradulations.
Re: Model T Racer
Post by Rich Eagle » Sat May 13, 2023 1:18 pm
Nice!!! Thanks for sharing the pictures.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Model T Racer
Post by Dan McEachern » Sat May 13, 2023 1:34 pm
With regards to the Winfield and the pump diaphgram- until you solve the part problem, you can disable the pump by removing the screws on the bottom of the float bowl and rotate everything. Then just disregard the accelerator needle and the carb will pretty much operate as a Model S Winfield.
There are a few very knowledgeable speedster folks in your local Redwood Empire T club- you should consider joining the club if you have not already done so.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Model T Racer
Post by Kevin Pharis » Sat May 13, 2023 3:19 pm
There’s some common confusion about how the accelerator pump needle works too… screwing the needle down into its seat sets the pump at its highest setting. Backing it out about 3 turns will pretty much disable it. The diaphragm return springs are known to get assembled on the wrong side of the diaphragm too
kmatt2
First Name: Kevin
Last Name: Matthiesen
Re: Model T Racer
Post by kmatt2 » Sat May 13, 2023 4:51 pm
You have a nice car and it should run well with that Rajo. I once owned a speedster with a similar type Rajo and it would do 80 MPH.
In your picture it looks like the SR carb is a little close to the generator terminal, I would add some insulation between the two locations. You asked for ideas on other wheel and chassis colors in place of the yellow. Both black or red would work, also silver / white , like your number is , would work. But on an era race car the yellow could have been used in order to draw attention to the car and most importantly the car’s sponsor.
