Bittner made a regulator to charge batteries from your mag post. I had one on my '12 and would like one for my '14. If you have one laying around and want to sell it text me.
thnx
frontyboy 2oh6-919-1949(Seattle)
						Bittner voltage regulator WANTED
				Kerry
- Last Name: van Ekeren
Re: Bittner voltage regulator WANTED
It is a shame that they are not made anymore, I use 2 of them, one 6v and a 12v.
ABoer
- First Name: Anthonie
- Last Name: Boer
Kerry , You can easy make a voltage Regulator by your self .
With the help of the drawing from John Regan. Toon
				Kerry
Toon, yes, I have seen that set up, I like the bitner ones as they were a nice sealed unit that one could mount under the floor or frame rail and be out of sight.
				Cap
- First Name: Cap
- Last Name: Weir
- * REQUIRED* Type and Year of Model Ts owned: 24 & 25 C Cab
This is the way I put together the wiring on a MAG Charged '13
It has an E-Timer, Running 6Volt
Cap
Cap
