Getting the 1910 racer on the road
Topic author - Posts: 1542
- First Name: Rob
- Last Name: Heyen
Home from Deans. Now to try sorting….
First start back home:
https://www.dropbox.com/s/c7v8oaj5q8l5h ... 3.mov?dl=0
And a quick test drive. It’s a little too fast on loose gravel to film and drive:
https://www.dropbox.com/s/004qaj3qs1jr9 ... 3.mov?dl=0
Re: Getting the 1910 racer on the road
Thanks Rob. It certainly made my day brighter.
- First Name: Rob
- Last Name: Heyen
Rich, my pleasure. Still fighting the 5-ball carb at low speed and idle.
Cheers,
Rob
Cheers,
Rob
- First Name: Keith
- Last Name: Gumbinger
Considering your rough idle makes me wonder what cam do you have in this, or how much lift compared to other cams, like 270, 280, 310, etc.? Just wondering...
Thanks, Keith
Thanks, Keith
- First Name: Leo
- Last Name: van Stirum
Big smile in the second video, good on you Rob, it took some time but are enjoying it again !
Leo van Stirum, Netherlands
- First Name: Rob
- Last Name: Heyen
Thanks Leo.
Kieth,
Not sure on cam/valve timing? I wish I had paid more attention when it was out. I have one intake lobe drawing:
Kieth,
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Did you get the distributor on it?
- First Name: harold
- Last Name: musolf
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
- Board Member Since: 2010
so if I did my math correct in my brain it has .375 lift , that's a lot of cam compared to a stock T at .250
Harold III
Harold III
- First Name: Rob
- Last Name: Heyen
Tim, we did. Works great! First time I can start the motor cold with the crank.
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1923 Mercury speedster replica, 1923 speedster
.375 valve lift, minus valve clearance.
I would call that a radical cam.
- First Name: Rob
- Last Name: Heyen
Scott,
That may help explain the problems getting it to idle and run smooth at lower rpm. Under load the motor seems to “reach down” and pull through. When I shift in the 2nd video it’s running rough, but pulls through without a miss when I shift to high, even though I don’t change the throttle (because I was holding the camera with my right hand).
One thing about it, it accelerates like a Chebby small block.
- First Name: Rob
- Last Name: Heyen
On another note, I checked the Model K drawings, and the K motor has the same cam lift as a Model T, .250, if my math is right…
- First Name: Mario
- Last Name: Brossard
What a beast, I love it, great job Rob. Nice video either.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Kim
- Last Name: Dobbins
I know you want to use the 5 ball, but if you can try a properly sized schebler, that may answer a couple questions. Have fun!!
- First Name: Rob
- Last Name: Heyen
Kim, Thanks. Bruce agrees with you. We’ll probably try that at some point. I’m putting a video up on anew link with the motor running on a trailer in near dark to see the explosions. It may be that we are firing a fairly even mixture, but the cam lift and timing may just not be capable of a smooth low engine speed without Ali ding rough.
