Getting the 1910 racer on the road
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Fri May 12, 2023 2:53 pm
Home from Deans. Now to try sorting….
First start back home:
https://www.dropbox.com/s/c7v8oaj5q8l5h ... 3.mov?dl=0
And a quick test drive. It’s a little too fast on loose gravel to film and drive:
https://www.dropbox.com/s/004qaj3qs1jr9 ... 3.mov?dl=0
Re: Getting the 1910 racer on the road
Post by Rich Eagle » Fri May 12, 2023 4:52 pm
Thanks Rob. It certainly made my day brighter.
Rich :D
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Fri May 12, 2023 7:38 pm
Rich, my pleasure. Still fighting the 5-ball carb at low speed and idle.
Cheers,
Rob
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Fri May 12, 2023 8:13 pm
Considering your rough idle makes me wonder what cam do you have in this, or how much lift compared to other cams, like 270, 280, 310, etc.? Just wondering...
Thanks, Keith
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Mon May 15, 2023 6:12 am
Big smile in the second video, good on you Rob, it took some time but are enjoying it again !
Leo van Stirum, Netherlands
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Tue May 16, 2023 10:44 am
Thanks Leo.
Kieth,
Not sure on cam/valve timing? I wish I had paid more attention when it was out. I have one intake lobe drawing:
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Post by Tim D » Tue May 16, 2023 10:48 am
Did you get the distributor on it?
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
Board Member Since: 2010
Post by flatbroke3 » Tue May 16, 2023 11:24 am
so if I did my math correct in my brain it has .375 lift , that's a lot of cam compared to a stock T at .250
Harold III
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Tue May 16, 2023 11:31 am
Tim, we did. Works great! First time I can start the motor cold with the crank.
tselliott
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1923 Mercury speedster replica, 1923 speedster
Post by tselliott » Tue May 16, 2023 11:34 am
.375 valve lift, minus valve clearance.
I would call that a radical cam.
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Tue May 16, 2023 12:03 pm
Scott,
That may help explain the problems getting it to idle and run smooth at lower rpm. Under load the motor seems to “reach down” and pull through. When I shift in the 2nd video it’s running rough, but pulls through without a miss when I shift to high, even though I don’t change the throttle (because I was holding the camera with my right hand).
One thing about it, it accelerates like a Chebby small block.
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Tue May 16, 2023 12:05 pm
On another note, I checked the Model K drawings, and the K motor has the same cam lift as a Model T, .250, if my math is right…
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Tue May 16, 2023 1:14 pm
What a beast, I love it, great job Rob. Nice video either.
Super Mario Bross ;)
1911 Touring
1914 Speedster
KimDobbins
First Name: Kim
Last Name: Dobbins
Post by KimDobbins » Tue May 16, 2023 10:46 pm
I know you want to use the 5 ball, but if you can try a properly sized schebler, that may answer a couple questions. Have fun!!
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Wed May 17, 2023 12:26 pm
Kim, Thanks. Bruce agrees with you. We’ll probably try that at some point. I’m putting a video up on anew link with the motor running on a trailer in near dark to see the explosions. It may be that we are firing a fairly even mixture, but the cam lift and timing may just not be capable of a smooth low engine speed without Ali ding rough.
