Himico Transmission
namdc3
First Name: Nikolaus
Last Name: Martin
Himico Transmission
Post by namdc3 » Mon May 13, 2019 9:45 pm
Any pitfalls on getting a Himico trans going again - unobtainable bearings, common problems, etc.? I suspect I know the answer, but any chance anyone has a spare clutch pedal or shifter taking up space on a shelf? Has anyone found a suitable replacement shifter - i.e., another brand that happens to fit? I think a ford clutch pedal could probably be modified to work, although it would be much nicer to have an original.
John Warren
Last Name: Warren
Re: Himico Transmission
Post by John Warren » Wed May 15, 2019 8:56 am
A friend was telling me about the optional transmission, Wow nice seeing it. Thanks jw
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed May 15, 2019 10:00 am
Got any pictures of the pan?
VWGary
First Name: Gary
Last Name: Schreiber
* REQUIRED* Type and Year of Model Ts owned: 22,26 & 27
Board Member Since: 2006
Post by VWGary » Wed May 15, 2019 10:08 am
Here is a link to a previous forum post. http://www.mtfca.com/discus/messages/17 ... 1316124771
Also if you Google "himico transmission mtfca" and click "images" there are quite few. I spelled it both ways Himico and Himco.
Former member of MTFCA, MTFCI, SCMTFCA
Don't have to be ashamed of the car I drive, I'm just glad to be here, happy to be alive.
namdc3
Last Name: Martin
Post by namdc3 » Wed May 15, 2019 7:36 pm
Here's a couple pan pics. The inspection cover is with it, and at first glance it looks to be a standard 4 dip cover. Note that the wishbone ball joint sits on top of the bracket instead of below it.
Thanks for the heads up on the links. I had kind of done a canvas of old content and didn't come up with much in the way of going through one. I did see someone listed parts for sale many moons ago, but the ad is old enough that it doesn't come up on the site anymore. From looking at literature, there was a pedal change from narrow to wide at some point, perhaps at the same time Ford changed their pedal style.
