Top fastener ID
- Last Name: Strange
- Board Member Since: 2013
Re: Top fastener ID
Burco fastener, I believe.  I'm not aware of a contemporary source for them, others can chime in.
Re: Top fastener ID
Older thread on those fasteners for the top rear gypsy curtain, finding repro of originals is difficult. Most go with Lift-the Dot fabric snaps and threaded posts.
http://www.mtfca.com/discus/messages/82 ... 1537828064
Re: Top fastener ID
From the thread that Dan linked, looks like they are called Anzo fasteners, not Burco.  Restoration Supply used to have a limited selection of them, I don't know if they still do.  Restoration Specialties also show some.
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
Re: Top fastener ID
I have I believe, three of these.  If you need them, I’ll send them to you.
									William L Vanderburg
1922 Center Door Sedan
				Don ellis
- First Name: Don
- Last Name: Ellis
- * REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Re: Top fastener ID
I have six of this side but not the part in the fabric. I’ll probably go with lift a dots, thanks
Re: Top fastener ID
Those Anzo's are for the side curtains.
Re: Top fastener ID
I forgot to mention, the female Anzo snap goes into those. I always pick them up at Hershey when I see them.
