Hi,
what is the expected voltage on a 6V model T equipped with the Fun Projects Voltage Regulator (VR) and engine running at some rpms well above idle?
Voltage with Fun Projects VR
dykker5502
Topic author - Posts: 503
- First Name: Michael
- Last Name: Deichmann
Ford Model T 1914 Touring
Moxie26
- Last Name: Jablonski
Re: Voltage with Fun Projects VR
7.2 to 7.4 vdc
dykker5502
Thx, that wasalso as expected, but I only see 6,3 volts. Better check the generator.....
Moxie26
The reading that you're getting refleects the charge on your battery and the load. Same reading with your headlights on ???
If you are checking the generator output on the generator side of the cutout, it should be read in amperes not volts and set for around 4-6 amps at medium fast idle. As said, if checking the output/battery side, that would be the battery voltage, there is line voltage at all times on that side.
