Size Matters
ModelTWoods
First Name: Terry
Last Name: Woods
Size Matters
Post by ModelTWoods » Thu Jun 08, 2023 11:03 pm
The Model T Ford transmission repair book, published by the MTFCA, recommends a 15 gallon solvent or oil drum makes a nice stand for an assembled T transmission for charging or other purposes. Fifteen gallon drums are much smaller in diameter than 55 gallon drums. My question is for someone who uses a 15 gallon drum for a transmission stand, WHAT is the diameter of the open top of a 15 gallon drum? I have a chance to get a 5 gallon oil can that measures 11 inches in diameter, but that seems to be a bit too small.
Re: Size Matters
Post by Steve Jelf » Thu Jun 08, 2023 11:32 pm
A flywheel measures 15", so I expect you want a drum at least that wide for a stand.
I don't know how many gallons that is.
Last Name: Tannehill
Board Member Since: 2002
Re: Size Matters
Post by JTT3 » Thu Jun 08, 2023 11:47 pm
A five gallon plastic bucket works just fine especially if you have one of those small shop stools sold at HB FOR $20
Re: Size Matters
Post by TRDxB2 » Thu Jun 08, 2023 11:49 pm
Checked the Internet for whats for sale Looks like 14"- 14-1/2 " OD
What are the dimensions of a 15 gallon drum?
-Capacity: 15 gallon. Black color. Measures 14-1/2-inches outer diameter by 25-inches
-15 Gallon Steel Drum Tight Head, New, UN-Rated (1 Each) ; Interior: Unlined, Weight: 14 lbs ; Outside Diameter: 14 13/16”, Outside Height: 25 ½”
-New 15 Gallon Steel Closed Head Drum This drum is 20 gauge. All drums are new, not reconditioned. This drum has a height of 25 1/2″ and an outside diameter of 14 3/8″
