We're mag coils sealed?
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Thu Jun 08, 2023 10:49 pm
When Ford built magneto coils, we're they coated with any sealer before or after mounting on the plate?
Also what type of fabric were they wrapped in and what would compare with it today?
Last Name: Tannehill
Re: We're mag coils sealed?
Post by JTT3 » Fri Jun 09, 2023 12:10 am
Info you may be interested in:
https://youtu.be/VTNQiabdZp4
Post by DanTreace » Fri Jun 09, 2023 9:57 am
Here is the Ford spec on the insulating varnish, note the first sentence that described the assemblies were coated.
jab35
Last Name: Bartsch
Post by jab35 » Fri Jun 09, 2023 10:01 am
Cotton twill overwrap on each coil, and final assembly coated in shellac-based insulating varnish.
jiminbartow
Last Name: Patrick
Post by jiminbartow » Fri Jun 09, 2023 11:48 am
Now a days, the coil wrappings are sealed with brushed on “Glyptal”, which was originally developed by Thomas Edison and his Company, GE to seal the wire windings of electric appliances such as fans and generators. It comes in clear and red. Since it is so tough and impervious to oil, many of us here have used it to coat the inside of our Model T crank cases and oil pans to prevent the buildup of sludge on the interior surfaces and to brighten the interior of the engine to improve the visibility inside the engine. Jim Patrick
