I was at a local Hill Climb and as I was looking over the cars, I found this unique mechanical carb adjuster.
Has anyone ever seen or used one. If so, anyone have one for sale.
George
Elkhorn, Nebraska
Mechanical carburetor adjuster
- First Name: craig
- Last Name: leach
Re: Mechanical carburetor adjuster
Hi george,
The gears are the hard part see Amazon Boston L125Y Miter gear 1:1 0.375" bore 1.25 they are $34.54
Unprr
Topic author - Posts: 294
- Last Name: Schmidt
- * REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Thanks Craig, I will go in this direction.
George
George
Looks like it would be easiest to use if you were laying on the floor! For a more finished look, adequate for what it is called upon to do, a nice gearset that is sized and designed for the forces encountered can be found here: https://www.mpcomponents.com/wp-content ... /Gears.pdf beginning page 46
MPC: https://www.mpcomponents.com/products/gears/
