FS: Bosch Accessory Distributor, Spacer, and Gear
WaltM
Topic author - Posts: 292
- First Name: Walter
- Last Name: Magas
For Sale, Bosch Distributor, spacer and gear. Gears are in good shape, distributor cap has good center brush, condenser, and points. This type of Bosch distributor does not need to be connected to the spark rod. Price $300 plus shipping. Call or text (248) 894-75fiveone. Thanks, Walt
DustySpokes
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Re: FS: Bosch Accessory Distributor, Spacer, and Gear
It even has the correct Factory colours ! -Dusty
WaltM
- Last Name: Magas
Someone had a request for the dimensions of the spacer. Spacer dimensions: Height 5/8-inch, ID 9/16-inch, and OD 3/4-inch. Hope this helps, Walt
