Buick piston used in Model T??
Topic author - Posts: 5426
- Last Name: Hatch
I have heard of a Buick piston used in in a Model T. With a Model A rod. Any idea which one? Thanks Dan.
Joe Bell
- First Name: Joe
- Last Name: Bell
Re: Buick piston used in Model T??
I pulled one down once that had Olds. pistons from the 260 mid 70's that where in this one. Hope this helps.
Kohnke Rebabbitting
- First Name: Herman
- Last Name: Kohnke
- * REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
We have used 312 Ford Forged Pistons in the 26-27 T Blocks.
Herm.
Herm.
modernbeat
- First Name: Jason
- Last Name: McDaniel
- * REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
The Ford 292 Y-Block piston looks like a potential winner.
3.75" bore
1.760" compression height
The wrist pin is 0.912", which could be fixed by adding a bushing to change the piston from a fixed pin to a swivel pin.
For the bigger bore engines, the 3.80" bore of the 312 would be used
3.75" bore
Jason McDaniel
D Stroud
- Last Name: Stroud
- Board Member Since: 2011
My old Buddy/Mentor used 292 Ford Y block pistons on at least one build, about 35 years ago or so, long before we had the internet and other info available. Some mods were done as I recall, but very doable. JMHO Dave
1925 mostly original coupe.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Using 292 pistons requires cutting and welding the connecting rod if you use A rods. Plus, they have very little dome on them so your compression ratio is going to suffer.
To each his own but what is the reasoning using other pistons when the Model T pistons are readily avaliable? Just wondering what’s the advantage.
Les Schubert
- First Name: Les
- Last Name: Schubert
The problem as I understand it is that pistons for A crank A rod T engines are no longer being offered. For those of us capable of doing the work ourselves this is a great economical solution
- First Name: Henry
- Last Name: Lee
Too funny Les, LMAO!
Hank in Tin-A-See
Hank in Tin-A-See
ModelT46
- First Name: Darel
- Last Name: Leipold
50 years ago many used the piston from 55 Chev. V8 They pin opening was bushed to use a Model T Ford pin.
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
John Steinbeck wrote about T's in a couple of his novels. In Grapes of Wrath, while the truck the Joads drove wasn't a Ford, Tom Joad goes to a junk yard at night and finds a replacement piston from another make vehicle to replace the piston & rod that went bad in their truck. This business certainly isn't new.
DickC
- First Name: Dick
- Last Name: Cruickshank
I have a 22 with 55 ford alum pistons.
- Last Name: Hatch
Where this going is I am looking for piston to use with a Scat Stroker and A rods. See my post about this crank with Scat rods. Looks like the A rods will hit the cam also! So, back to drawing board. Dan
Randall strickland
- First Name: Randall
- Last Name: Strickland
Hey Dan rods will not hit cam I have these in my engine and I know of at least one more running the same parts
Randall
Randall strickland
Forgot to say you do have to go down with a end mill and cut a little clearance on the front cam boss on the block not hard to do,hope this helps Randall
- First Name: Henry
- Last Name: Lee
Besides what Randall stated, the only other nicking was on a Roof 310 cam for me. Nicked the rod just a little, then re-balanced the others to match.
All the Best,
Hank
All the Best,
Hank
