Engine Stand help
Flyingpiper59
First Name: Edwin
Last Name: Douglas
* REQUIRED* Type and Year of Model Ts owned: 27 Tudor
Engine Stand help
Post by Flyingpiper59 » Wed Jul 05, 2023 10:39 am
Good morning Forum and Chums,
I’d like to ask for your help one more time here on my 27 Tudor restoration. Initially I was just going to do an engine refresh as the engine wasn’t overly worn…..was gonna just keep the engine and trans in the car…….had wanted to get rid of two piece valves, install a re-ground or new Stipe, cam, etc..
Unfortunately, I found the transmission doesn’t wanna cooperate with my plan…. so now I am afraid the engine has got to come out and I have to address some very loose triple gears.
Getting the engine out, it’s not gonna be a problem, where I would like some help is with engine stand…. If anyone has a picture or two of your model T engine on an engine stand, I would dearly like to see them to get some ideas of something I can fabricate or possibly an adapter that I could purchase….
I have found that getting input from you fine folks that have been there and done that is invaluable….. many thanks in advance for any pictures, and or advice…..Cheers!
TrentB
First Name: Trent
Last Name: Boggess
Re: Engine Stand help
Post by TrentB » Wed Jul 05, 2023 11:57 am
My personal favorite is the KR Wilson engine stand on a roller base.
The advantages I see in his stand is that there is very little flex of the stand with the motor on it. More modern stands made from welded square tubing always have some movement when holding a heavy Model T motor assembly.
Another advantage is the motor can be rotated to almost any position, making it pretty easy to,work on different parts during assembly/disassembly.
On the roller base, it is pretty easy for me to move the stand with the engine mounted around my shop.
Of course the KR Wilson stands are not cheap or easy to come by, a definite disadvantage.
Respectfully Submitted,
Trent Boggess
Post by TRDxB2 » Wed Jul 05, 2023 12:13 pm
There is no bracing in the rear around the transmission other than on the bottom. Wheels make it easy to move around if you don;'t have a large work area
Scott C.
Last Name: Clements
Post by Scott C. » Wed Jul 05, 2023 12:59 pm
Here is a picture of an engine on my stand. The stand I built in high school as a shop class project. The plate is the one that the vendors sell.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Wed Jul 05, 2023 1:01 pm
Per instructions, I made a set of these in April.
3/8"
engine stand bolts.jpg (82.41 KiB) Viewed 1904 times
Vern (Vieux Carre)
Last Name: Kuehn
Post by John kuehn » Wed Jul 05, 2023 1:19 pm
The engine stand I bought from Harbor Freight tools works fine for me. More than good enough for a T engine. It’s reasonably priced and well worth it. Also get you the engine mount adapter plate that Lang’s sells. It works with any modern engine stand that adapts it to hold a T engine.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Jul 05, 2023 1:26 pm
Hi Edwin,
This is what I came up with from a $25 swapmeet find some flat iron & some bolts. The flat slots make it eazy to from engine to engine & trans
to keep it balanced.
engine stand.jpg (24.76 KiB) Viewed 1882 times
engine stand1.jpg (28.56 KiB) Viewed 1882 times
It is tight geting to the main bolts. I also made a fixture to hold a rear end in the stand with 2 exhaust clamps.
Craig.
Post by Scott_Conger » Wed Jul 05, 2023 1:34 pm
If I did not have a stand like Trent, I'd use a standard engine stand with this adapter: https://www.modeltford.com/item/6005-ADP.aspx it is the gold standard of adapters...
this plate that most folks buy, that bolts onto a stand is OK but not the greatest unless $$ are a concern, and I do not discount that being a factor for many folks
Post by Steve Jelf » Wed Jul 05, 2023 2:06 pm
With a tendency to overcomplicate, I made my adapter adjustable to put the center of gravity at #4 with transmission on and between #2 and #3 with it off. Like most other T adapters, it has two ⅜" pegs at the bottom and two bolts at the water inlet.
Post by DanTreace » Wed Jul 05, 2023 2:14 pm
Note the better engine stands are 4-wheel, recommended.
Have used the cheap tri-pod 3-wheel stands with the vendor adapter plate for the block, but this style is rather un-stable, so use real caution!
15 engine and trans apart.jpg (116.39 KiB) Viewed 1839 times
Flyingpiper59
First Name: Edwin
Last Name: Douglas
Post by Flyingpiper59 » Sat Jul 08, 2023 9:27 am
Thanks all….. I now I have some ideas for fabricating a mount for my stand!
Cheers!
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Sat Jul 08, 2023 12:36 pm
Engine stand adarter for rear ends.
rear end adapter.jpg (27.47 KiB) Viewed 1613 times
Craig.
