WTB: Steering Shaft
				Scott C.
- Last Name: Clements
WTB: Steering Shaft
I am needing a good steering column shaft for my 26 Coupe.  The vendors are all out of stock.  Does anyone have a new one lying around or, a good used one that you are willing to sell?  Or even a complete steering column with a good shaft.
Jeff Perkins
- First Name: Jeff
- Last Name: Perkins
Re: WTB: Steering Shaft
I have a good used one + gears…..pm me to talk.  Jeff P. in MN
									1926 Model T Touring,
1948 Chrysler New Yorker,
				Scott C.
I sent you a PM.
Jeff Perkins
- First Name: Jeff
Hi Scott,
I sent a PM yesterday and an email w/ pictures just now.
Thanks, Jeff P.
Thanks, Jeff P.
				Scott C.
Still looking.
				ModelT46
- First Name: Darel
- Last Name: Leipold
How do you determine if the shaft is   for 26-27  and not 12-25?
				ModelT46
- First Name: Darel
also show the difference of the franme bracket 26-27 from the 12-25.
				Scott C.
The 26-27 is a 5 to 1 ratio.  The top of the shaft where the gears and pins go should have a 5 stamped into it.  The hole spacing is different than the earlier 4 to 1 type.  I believe that all of the reproduction shafts are 5 to 1.  The 26-27 column has a square mounting plate where if bolts to the cowl. Here are pictures form Lang's website of the 26-27 box.  I am not sure of the difference.  I think maybe it mounts at a different angle.
The earlier steering bracket is quite a bit different in design.
