timing with a 270 regrind cam
mike37 cdn
First Name: mike
Last Name: mclean
Post by mike37 cdn » Tue Jan 15, 2019 8:40 am
re building my 26 engine bought a 270 regrind cam just wondering if I need to set the timing different than the stock at 15 dec atdc i put in new ss valves and adjustable lifters and running high compression pistons thanks mike
Re: timing with a 270 regrind cam
Post by Mark Gregush » Tue Jan 15, 2019 11:57 am
Same as any other T, just after top dead center. You are setting for the spark to happen just after to prevent kick back. After that setting to where it runs best.
