on the top of the choke there is a rare curved tube similar to a hat pipe the books do not show the part number or the name does any one know the correct part number or name
I always called the the hot air pipe for the vaporizer but its not correct, will try to post photo when I find one
						Vaporizer question
richc
- First Name: Rich
- Last Name: Chillingworth
- * REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
Re: Vaporizer question
I posted a similar question not that long ago and the consensus was that the intake elbow was used on the early vaporizers, but dropped later on.  The pic below shows the elbow for both Holley and Ford versions (left) and the Holley and Ford non elbow versions (right).  You’ll notice the elbow vaporizers had a bolt hole on the inlet to mount the elbow.
Rich C.
				FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
thank you, Bob
