AWARDED the GOLD at the 2023 MTFCI tour in Baraboo, Wi.
SCAT Counter balanced stroker. Z Head, Stipe improved grind camshaft, Ruxstell Hi speed rear end, Twin Hi-Lo auxiliary (under, direct & overdrive) transmission, Heil dump box, "Sure Stop" Hydraulic disc brakes, Stainless steel exhaust pipe & muffler, Adjustable valve lifters (2 wrench style), Two auxiliary oil systems, Stewart speedometer, 6 vdc to 12 vdc transformer for charging phone/GPS, Directional signals, John Regan voltage regulator, Kevlar bands, "Belly Sling" oil pan support, Neville "Fatman" steering wheel, Tool Box, Auxiliary gas cans, Brassworks flat tube radiator, Turbo 400 clutch discs, Handbrake extension, ANCO "Hot spot" intake/exhaust manifold and much more.  $16,500 call or text at 920-226-1005 as well as email 26modeltt@att.net
													SOLD ---1926 Ford Model TT dump truck.
				26modeltt
- First Name: Jack
- Last Name: Leonhardt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
JH1427
- First Name: Jerome
- Last Name: Hoffman
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 Roadster, 1923 Speedster, 1923 Racer, 1921 TT Wood Cab
Re: 1926 Ford Model TT dump truck
Congrats Jack!
									model_t@swbell.net
Projects: 1916 Speedster - Dec 15', 1921 TT Wood Cab and Bed, 1923 Racer ( My dad's), 1923 Speedster (started in HS)
1924 Roadster - Dec 23' (eBay) and 1924 Touring - June 24' ( Dad's Car been in the family since 1948)
				26modeltt
- First Name: Jack
Thank you, Jerry, and take care.
Jack
						Jack
				KeithG
- First Name: Keith
- Last Name: Gumbinger
Friends, I know Jack and have toured with him & his TT truck many times.  This is perhaps the nicest TT out there.  With these auxilliary transmissions it keeps up with T cars on tours easily.  I can't say enough good things about this TT.
Keith
									Keith
				26modeltt
- First Name: Jack
Thank you, Keith, much appreciated.
