Is this Rajo stuff?
FlyingMerkel
Topic author - Posts: 83
- First Name: Daniel
- Last Name: Kraft
Is this Rajo stuff?
These came together with a Livingston radiator cap. Are the rockers Rajo? Thank you!
- Attachments
- EC704F3A-4A6B-48BE-ABD6-0F3D7C21B264.jpeg (37.84 KiB) Viewed 1394 times
- 2D60CBD5-7D32-440B-89C9-3707B623F15B.jpeg (39.55 KiB) Viewed 1394 times
- 509E9F99-01DB-4852-9360-AB9BC5996F90.jpeg (40.24 KiB) Viewed 1394 times
robert daniello
- Last Name: D
Re: Is this Rajo stuff?
I sent you a message.
Mark Chaffin
- Last Name: Chaffin
The rocker assembly is not RAJO.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Looks like small block Ford- 292-312 etc. Some folks think they will work on a T overhead, but the geometry is totally incorrect.
Cordes_jeff
- First Name: jeff
- Last Name: cordes
- * REQUIRED* Type and Year of Model Ts owned: 25
Ford y block ran solid lifters and adjustable rocker arms. Those are not Y block292-312
