Truckford chassis
Topic author - Posts: 1036
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Truckford chassis
i have what appears to be a "Truckford" chassis conversion ... a video was posted on the forum several weeks ago that identified this chassis ...EXCEPT that this is a later version than appears in the video ... the Ford chassis has the later front and rear crossmembers and the rear drive is SHAFT instead of chain drive ... the rear axel and spring setup is similar to mid to late 1920's International Harvester trucks i have seen ... there are no vin numbers stamped into frame rail ... i purchased this from Martin supply and salvage for the engine.trans unit about 12 years ago ... the chassis had been in the yard since the early 1950's and was believed to have been a Mountian School Bus ... the body was removed before the chassis was junked ... this is a solid unit that would be a good chassis for a truck or bus build ... this is the only one i have seen , so documentation will probably be difficult or non-existant ...NO TITLE ... price is $200 as pictured or $100 with the front axel and spring removed ...Gene French phone 970-581-2808 address is 49519 cr23 nunn,co. 80648
PICKUP WITHIN 30 DAYS ... I WANT THIS GONE
- First Name: Gene
- Last Name: French
Re: Truckford chassis
this chassis is still available ... i will remove front axel and oil pan ... price for the remaining frame rails and rear axel is now $50.00 BUT this must be removed by JULY 31,2023 ... i am cleaning up excess "projects " ... i have a endloader on site and will help load on your trailer ... this is probably about 1500 lb. and is worth more for scrap than the $50 price ...always an optimist ...Gene French 970-581-2808 ... ( NOTE ) chassis is at my homesite/shop in northern Colorado ( 49519 cr.23 Nunn,Co. 80648 )
- First Name: Gene
- Last Name: French
to the top again ... not too many days before this gets scraped ... i will remove the car chassis components and the rest will go to China to make happy meal toys ...Gene French
- First Name: Bob
- Last Name: Pilkie
- * REQUIRED* Type and Year of Model Ts owned: TT trucks and speedsters.
Please don’t scrap it. Not many of those frames around. Wish I was closer but I’m in Edmonton Alberta
- First Name: Gene
- Last Name: French
Bob:
i have had this frame for a long time ... this is the only one like this i have seen ... this is a very well build chassis and is in good re-buildable condition ... i am surprised that no one in this region has stepped up to take this project on ... i have way too much stuff and no interest in a big truck ... always an optimist Gene French
- First Name: Gene
- Last Name: French
Bob:
sadly it seems that there is no interest in this Truckford chassis ... i am offering this for FREE ( minus front axel and oil pan ) AND i will help to load this ... looks as though Jason the scrap guy will be getting this chassis and some electrical panels and junk farm equipment ... more materials to go to China ... the new deadline is Aug. 19-20 ... after the swapmeet the scrap iron goes to my neighbor jason ... always an optimist Gene French 970-581-2808
China needs metal for the War Effort.
- First Name: Joshua
- Last Name: Powers
- * REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
I wish you were closer, I would definitely get it. It would be a shame to see it scrapped.
I worked on a Truck with one of these conversions. Got it running and drove it around the yard. It was rated as a TWO ton truck with that conversion. The whole lot was very well made, except the jack shaft between the motor and rear axle. This looked a bit home engineered, and on this one it may well have been.
- First Name: Gene
- Last Name: French
Allan:
this chassis is very well built ... i was told that it had been a "Mountain school bus " ... all the fitting of components is well done , items are clean and straight as they should be ... the rear axel is like the type used in the International Harvester trucks of the mid to late 1920"s ... a quality unit , but completly lacking of any body components that would define the original purpose or rating of the vehicle...this could be re-built in a variety of configurations ... a blank canvas so to speak ... hope someone steps up to the plate and takes this unit ...always an optimist ...Gene French
- First Name: Gene
- Last Name: French
the Truckford chassis is spoken for ! thanks MTFCA
