What am I looking at. Says 1925.
Paperman
Last Name: Kesling
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Post by Paperman » Tue Aug 01, 2023 8:27 pm
Want to take a drive to look at this TT(?). Looks to have a 26-27 trans with coils on the cowl? The lever by the seat, is that a two speed? Neat looking, not your standard body.
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Re: What am I looking at. Says 1925.
Post by Model T Mark » Tue Aug 01, 2023 9:44 pm
I have seen it I live about 5 miles from there call me. Mark Eyre email me through this site and I’ll share my phone number.
Post by Norman Kling » Tue Aug 01, 2023 9:52 pm
Looks like a TT stake truck. However the hood likes like a 26.Hard to tell because it could have been first sold in the fall of 1925.
Post by RajoRacer » Tue Aug 01, 2023 10:00 pm
Nice "aftermarket" truck cab, short running boards so pre-'26 BUT has 20" rear wheels and the front axle appears to have the '27 dip ! '26 - '27 engine & trans. - quite the different shifter than what I've seen before !
Post by Wayne Sheldon » Wed Aug 02, 2023 5:40 am
It is somewhat unusual for a 1925 through 1927 TT truck to have such a nice after-market cab on it. The Ford factory closed cab was a fine, solid , and practical one at a very reasonable price. It just didn't make sense to buy a chassis and then a body separately unless there was some special feature required for its intended use.
That looks like a really nice cab!
The hogshead does appear to be 1926/'27, and likely bolted to the back of the block, which makes it likely that he block is also 1926/'27. IF the truck was manufactured after December of 1925, there should be a serial number stamped on the top of a frame rail underneath where the floorboards should be. It is usually near the hand brake cross shaft, and can be on either side. IF that number is there, it can give you a "manufacture date" that would be almost to the day the truck was assembled at the Ford factory.
However, on these old trucks, a lot of things got changed over the years. The engine, the wheels, even the cab itself could have been changed at almost any time in the last 95 years. Pinning down the correct year n them can get tricky.
Good luck with it! It looks like a really good TT truck.
Last Name: House
Post by George House » Wed Aug 02, 2023 6:26 am
All TTs had the coil box on the firewall.
