FS Wood wheel rear hub assembly
Topic author - Posts: 280
- First Name: Brooks
- Last Name: Schlieben
- * REQUIRED* Type and Year of Model Ts owned: 1923 TT
Wood wheel rear hub assembly.
Primed.
$75.00, plus shipping.
PM
Or text at six zero nine nine two zero four two two zero.
Primed.
PM
Re: FS Wood wheel rear hub assembly
Brooks, the most important part of a good hub is the condition of the keyway. A photo from the other side showing it would help potential purchasers.
Will do, tomorrow.
Thanks, Allan.
Thanks, Allan.
The keyway looks good. Should be a decent hub for someone in need. Because the key is shorter than the keyway, the keyway from the outside can appear unblemished, as your first photo showed.
Thanks, Allan.
To the top.
To the top.
To the top
To the top
