Odd piece came in with a load of T parts
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Re: Odd piece came in with a load of T parts
Looks like part of a pump jack for a windmill.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Erik is right, part of a water pump jack system, most likely hooked to a Monitor engine. That piece clamps to body of water pump.
dobro1956
- First Name: Donnie
- Last Name: Brown
I'll add a third for Monitor pumpjack.
Yes, pump jack. I bought one for $1 at an auction, probably because I was the only one there who knew what it was.
Steve
do you use it, or did you waste a $ ??
Erik Johnson
- First Name: Erik
Please delete Marians profile. I'm pretty sure the poster is a AI BOT based on responses in other threads including this one.
