another supplier of pliers?
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Tue Aug 15, 2023 4:10 pm
I picked up this pair to drain my compressor and just happened to notice the makers mark on one side and Ford on the other. I don't think I have seen a pair like these before. It looks like it says Herbrand, USA
Re: another supplier of pliers?
Post by Steve Jelf » Tue Aug 15, 2023 4:42 pm
Those pliers are the reason for the high price of Model T screwdrivers. When they started putting that flat end on one of the pliers handles, they quit making the screwdrivers, which makes them scarce today. I believe all the kit tools were made by various manufacturers. Herbrand was one of them.
Post by John kuehn » Tue Aug 15, 2023 4:58 pm
I have a pair of well used pliers but no markings like the ones pictured. The screwdriver end drawback is when you are getting down on a nut or something the sharper end of the pliers can bite into your hand!
Post by Scott_Conger » Tue Aug 15, 2023 6:38 pm
John, I think that's why they make wrenches! :lol:
I always thought stories of folks using pliers to put on or take off nuts was a wives' tale ;)
Post by speedytinc » Tue Aug 15, 2023 7:05 pm
Best hardware knackering tool there is. :D :D
Post by John kuehn » Tue Aug 15, 2023 9:10 pm
When you’re broke down in the pasture and that’s all you have in the tractors tool box you use what you have. But Ido use a crescent wrench sometimes! 👌
Post by John kuehn » Tue Aug 15, 2023 9:14 pm
When you’re broke down in the pasture and that’s all you have in the tractors tool box you use what you have. But I do carry a crescent wrench and I’ll bet I’m not the first that used a pair of pliers with the screwdriver end and that bit his palm! And they were Model T owners back in the day that did too!
Post by Scott_Conger » Tue Aug 15, 2023 9:27 pm
John
no offense was ever intended if you took it that way...I just couldn't resist ;)
Post by Allan » Wed Aug 16, 2023 4:03 am
John, in Australia there are so many unbranded sets of those pliers I think many of these may well have been T model issue. However, if it has a Ford script, it is hard to argue that they are not T model ones. We get English made ones too, but they are slightly different in handle shape, so are most likely from little English 8 and 10 HP cars.
Post by Original Smith » Wed Aug 16, 2023 11:56 am
The Herbrand pliers are not common. I also disagree with Steve Jelf's comments.
Post by TRDxB2 » Wed Aug 16, 2023 12:47 pm
Does this disagree with the disagreement?
Where did all the screw drivers go? Likely they found their way into the workshop to be used as a screwdriver, paint can opener, pry tool etc until the tips were gone, and then trash
