What is this? Part number?
Topic author - Posts: 7330
Actually I know what it is, I think. But I haven't found it in any parts book or catalogue. Anybody know the official name and number?
Re: What is this? Part number?
Can't tell by the length...but brake rod clevis pin?
- First Name: Terry & Sharon
- Last Name: Miller
Hello Steve,
That is a clevis pin. I just looked up Lang's and they have a whole bunch of them. You'll need to measure diameter and length to know what to order. I'm sure Snyder's has them too.
Good Luck,
Good Luck,
- First Name: ROBERT
- Last Name: BERGSTADT
T-3905 Starting crank ratchet pin if long enough, Bob
I was thinking clevis pin from the front and rear ends of the hand brake rods. I finally found them (2546). They're ⁵⁄₁₆", but shorter than the crank ratchet pin. It's also ⁵⁄₁₆", but longer at 1⁷⁄₁₆". As Bob says, that's 3905. Now I know which drawer it goes in.
Thanks, all
Thanks, all
Don't forget the clutch lever. There was a discussion recently on the early style domed head clevis pins.
The clevis pin in your photo is p/n 2564, and is clearly pictured on page one in my 1925 parts book under rear axle.
That part isn't listed in my parts book under transmission control, but it is in my 1913 parts book under a different number, BUT the factory number is the same #65.
- First Name: Mario
- Last Name: Brossard
Thank you for the info, I didn't know neither... Always learning on this forum.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
