Hi All,
I've seen an example of a rear axle where the keyway was very damaged, and wondered if anyone had attempted to do any welding and grinding to get the keyway area back to normal. Is this a practical thing to do? I have some slight damage on the axle at the keyway and wondered if I could/should attempt to repair it so the key will stay in the slot better. Thanks,
John
weld repairing keyway slot on axle
NY John T
Topic author - Posts: 443
- Last Name: Killelea
Re: weld repairing keyway slot on axle
Sorry this belongs in the General discussion area....
Not a good idea when new axles are available.
Layden Butler
- First Name: Layden
- Last Name: Butler
If the taper is good, a new keyway could be cut on the other side from the bad one. BUT not a real good idea because it will weaken the axle.
Replace it! There are lots of good used axles out there.
