1927 Coupe Before Restoration
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
The attached photos show my coupe in storage before restoration.
- First Name: Fred
- Last Name: Schrope
- * REQUIRED* Type and Year of Model Ts owned: 1923, 1926, 1927 TT's, 1918 cutoff touring, 1922 Coupe - original
Re: 1927 Coupe Before Restoration
No way would I restore that one.
Just give it a bath and get it running properly and safely and drive it.
You'll be considerably richer also.
Opps, I guess I should have waited until you finished.
To late now.
It does look good though.
To late now.
- Last Name: Humble
Good Job Bruce. Looks great.
- First Name: Harvey
- Last Name: Bergstrom
Beautiful restoration! The product of hard work & perseverance.
- Last Name: Gould
Kudos on a quality restoration. The car is a pleasure to behold
Nice redo but I would have cleaned it up, got the mechanicals right and started driving it. But it does look nice. Two points of view of what to do to a T when they are found in nice shape. Clean it up or restore and there will always those points of view. As long long as you can find a nice original it will be that way but they are getting scarcer.
- Last Name: Codman
If I had the time and space, I wooda done what Bruce did. The car is beautiful.
- Last Name: Jorgensen
Nice work. You should be proud.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
