Manifold Gaskets
70shovelhead
First Name: Preston
Last Name: Wells
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1926 TT Truck
Board Member Since: 2008
Manifold Gaskets
Post by 70shovelhead » Mon May 20, 2019 8:58 pm
What is the prefered type of manifold gasket material. Copper rings or 2 piece asbestos. Currently using asbestos but had one start leaking last week.
70shovelhead
"There is more to life than what we see"
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
1919 IHC Titan 10-20
First Name: Dallas
Last Name: Landers
Re: Manifold Gaskets
Post by Dallas Landers » Mon May 20, 2019 9:01 pm
Copper rings and gland rings. I tried the cheap ones and had same problem.
Post by Norman Kling » Mon May 20, 2019 9:19 pm
I prefer the copper rings. Regardless of which type you use, you need the glands at least on the exhaust ports to keep the manifold from sagging.
Post by Original Smith » Mon May 20, 2019 9:48 pm
If you are lucky enough to have a straight manifold, continue using the originals. The reason the manifolds warp is because of the 3 in 1 gaskets.
Post by Steve Jelf » Tue May 21, 2019 1:21 am
The stock gaskets and rings keep the exhaust manifold straight, as Larry says, and the last time I checked they were less than half the price of the copper one-piece gaskets.
If your block is pitted like this one you can add a little hi-temp RTV to help the gasket seal.
70shovelhead
First Name: Preston
Last Name: Wells
Post by 70shovelhead » Tue May 21, 2019 11:17 am
How about this?
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
Post by Steve Jelf » Tue May 21, 2019 11:44 am
How about this?
They're fine, but look at the price. More than three times the cost of the stock parts.
70shovelhead
First Name: Preston
Last Name: Wells
Post by 70shovelhead » Tue May 21, 2019 5:51 pm
Thanks for the suggestions. I ordered a set of original Ford type gaskets from Macs. I know I had used these about 20 years ago but cant remember why I went to the 3 in 1 type.
70shovelhead
1923 T Roadster
1926 TT Truck
1948 Willys Pickup
1937 Harley WL45
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Wed May 22, 2019 1:33 pm
This is a case where newer is definitely not better - the trick to the 3 piece original style is that steel "sleeve" in the middle is what supports your exhaust manifold and keeps it from warping. The copper one piece ones don't support as well, and the flat ones are almost guaranteed to warp your exhaust manifold.
Plus the 3 piece ones are cheaper. And cheap is always good - just ask Henry!! :lol:
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Wed May 22, 2019 2:46 pm
12 piece is the best, we make the gland rings right here in the shop, Bob
Last Name: Wrenn
Post by TWrenn » Wed May 22, 2019 3:46 pm
Preston...despite the high cost, in my not-so-humble opinion I believe what you pictured above are the best, hands down. I have 'em on all my T's, past and present! No problems with these kind!
Stu Tomlinson
First Name: Stuart
Last Name: Tomlinson
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1913 Huckster, 1924 Touring, 1927 Tudor
Post by Stu Tomlinson » Wed May 22, 2019 9:41 pm
Here is a thought for discussion: Those little flimsy split gland rings that slip inside the manifold ports are not going to keep that manifold from moving. The mass of the manifold is so much larger than those rings - so when things go to heating, moving and expanding - the manifold will win every time. When that manifold expands it is going to move - and those ring will not stop it. When you remove the exhaust manifold, you are better off to straighten it or replace it. Those rings then make it very nice to line things up evenly with the exhaust and intake ports and you can always use the round copper gaskets. Your best off with the straight manifold and keep those 4 nuts torqued and tight - and even then, those manifolds will still want to expand and bend.
I have installed warped manifolds in which you have no choice but to use the two piece gaskets because nothing else will work. In this case, I install the two gland rings for the intake manifold - because they will always line up and seat correctly. I use just one ring for the exhaust manifold installing it on the front or the back. With a few pencil traces in various positions you can get the manifold to a "best fit" situation with out causing an exhaust manifold leak. Not ideal, but this solution will work.
Post by Steve Jelf » Thu May 23, 2019 12:16 am
A warped exhaust manifold will straighten nicely if it's no more than ¼" out of line. Any more than that, and you'll probably need to find a better one.
Post by Allan » Thu May 23, 2019 7:53 am
Tim and Preston, those one piece copper gaskets must be good. They are made in Australia! They are far cheaper here. If you check on line at Fuel Tank and Radiator Services, you may find it cheaper to buy them directly, even with the added postage. You could probably get three or four sets for the same postage cost. I love them!
Hope this helps.
Last Name: Wrenn
Post by TWrenn » Thu May 23, 2019 8:04 am
Thanks Allan. I love them too!
Happy motoring.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Thu May 23, 2019 9:37 am
Others may have a different opinion, but I find these copper "gland" gaskets can be re-used, probably several times if that were necessary, which makes them cheaper in the long run. Years ago, glands of this type made of aluminum (I think with an asbestos core) were available, and were much softer. They could only be used once.
"Get a horse !"
