Unusual Mixture control
Last Name: Juhl
Post by Oldav8tor » Tue Aug 29, 2023 10:49 am
Has anyone seen a mixture control like this? A friend has a mostly unmolested roadster with this little gem.
Re: Unusual Mixture control
Post by Norman Kling » Tue Aug 29, 2023 10:54 am
Never saw one like that! I wonder if that was home made or was sold somewhere aftermarket?
Post by Rich Eagle » Tue Aug 29, 2023 12:31 pm
It doesn't look home made to me. Accessory or off some other make.
Maxwell used this one in 1915 and later. I'm sure other makes did also. Having a preset range would be handy. Not having to reach under the dash would be nice too.
Post by Jerry VanOoteghem » Tue Aug 29, 2023 12:35 pm
Not homemade. I have a similar unit on my Roadster. Mine has the exact same gear set-up, but in addition to mixture adjustment, it also controls the choke.
Post by TXGOAT2 » Tue Aug 29, 2023 12:42 pm
That's a nice one. A person could make a good one out of a length of speedometer cable. Mount a dial and knob wherever you want it and run the cable to a bracket on the engine. A similar arrangment could provide a dash mounted fuel shut off. Later models would need another bracket to divorce the choke function from the mixture control.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Tue Aug 29, 2023 1:12 pm
Here is a better picture of the face. It is marked "MADE BY THE IMPERIAL BRASS MFG CO" followed by a city and patent date that are illegible. The far left side of the dial is marked "RICH", the far right side is marked "LEAN".
Post by Jerry VanOoteghem » Tue Aug 29, 2023 1:26 pm
"Chicago, USA"
"Pat. Appld. For"
Ron Patterson
Post by Ron Patterson » Tue Aug 29, 2023 9:24 pm
Not to much news there.
Rignty Tighty=leaner. Lefty loosey+Richer.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Wed Aug 30, 2023 5:29 am
We have another 'Imperial' very similar in our 'Aftermarket' section with a few comments too: app.php/gallery/image/2886
Post by DanTreace » Wed Aug 30, 2023 10:36 am
This one is my fav. "Karfve" gas adjuster... Has a knob to twist and adjust the gas, and if you pull on the knob, it chokes the carb! Unique universal joint to make the angle from the dash, and a loop wire on the shaft to pull up the choke butterfly. Think Ford got the idea for the later NH carb combo adjust for the later '25-'27 from this product.
Ford NH later design combo dash control
528269 (494x500).jpg (95.99 KiB) Viewed 1133 times
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Aug 30, 2023 2:20 pm
Whenever stuff likes this comes up on the forum, I search Google books and find references in trade journals and catalogs.
When searching "Imperial Brass Mfg" they are listed as a carburetor, carburetor parts (ex. floats) and hubcap manufacturer in automotive and tractor trade journals.
Here is a link to an advertisement for their carburetor and choke control in a 1925 issue of "Automotive Merchandising." Note that it is the revised version that utilizes the stock hole in the instrument panel.
https://books.google.com/books/content? ... gew&w=1025
Chris Bamford
First Name: Chris
Last Name: Bamford
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster 1926 Touring
Post by Chris Bamford » Wed Aug 30, 2023 2:35 pm
Here is the mixture control in my '24 Speedster, same as shown by Oldav8or in the initial post. I have the info dial but an under-mount worked better on this dash.
