Mag Horn for sale Sold
elliott1936
Last Name: Elliott
Post by elliott1936 » Thu Aug 31, 2023 3:47 pm
Magneto horn with mounting bracket. The horn is in need of a clean up. I think it works as It make a sound when I touched it to a 12 volt. Price is $75.00 plus the ride. Tom five03-644-937four. It appears to be in good shape with no dents.
Last Name: Tannehill
Re: Mag Horn for sale
Post by JTT3 » Thu Aug 31, 2023 9:17 pm
Tom might not be good for the horn to test it with a battery.
Best John
Post by Mark Gregush » Fri Sep 01, 2023 10:13 am
Just touching it to 12 volts DC should not hurt it. It is just an electromagnet using AC that pulls the diaphram back then releases it 16 time per revolution of the flywheel. Checking it on DC would tell you that the windings are working when you hear the "clunk".
Novice
First Name: Jim
Last Name: Davis
Post by Novice » Sat Sep 02, 2023 12:46 pm
If You have a old toy train transformer that should work to test it. adjustable voltage 0 to 24 volts a/c. 60 cycles
elliott1936
Last Name: Elliott
Post by elliott1936 » Sun Sep 03, 2023 7:34 pm
Horn Has been Solded. Tom
