Looking for a nice modified Engine - Complete
				1915Smitty
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Roadster
Looking for a complete modified Engine with Skat or Model A crank, high compression head, Aluminum pistons-- all the goodies.
Contact me at 513-907-4755 via text or voice; or send pictures to 2creeksjeff@gmail.com
Bill Everett
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
Re: Looking for a nice modified Engine - Complete
E-Mail sent.
- First Name: Henry
- Last Name: Lee
It appears he is just fishing and not serious.., Does not respond to emails.
Hank
						Hank
				Gen3AntiqueAuto
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
I sent an email - check your spam folder if you didn't get it.
									1915Smitty wrote: ↑Thu Aug 24, 2023 9:42 amLooking for a complete modified Engine with Skat or Model A crank, high compression head, Aluminum pistons-- all the goodies.
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
- First Name: Henry
- Last Name: Lee
I did get a response just a while ago so he is real. I owe an apology.
Hank
						Hank
				1915Smitty
Thanks to all you responded- I have figured out a solution using my current 1912 block.
- Last Name: Tannehill
Jeff, the 1909-1912 blocks only have one support cast for the 3rd main. Some people have had serious issues at the 3rd main because of that design. Besides being a weaker design than 1913- forward with 2 strengthening supports casted in the block, rebuilding the early blocks without proper alignment & balancing of the transmission & engine could contribute greatly with a fail on those engines. Especially if driven frequently. Perhaps giving consideration to Hank Lee’s expertise or Tim Foye’s engine option would be a possible better solution. Just my two cents. Good luck John
