Carburetor dilemma
dykker5502
First Name: Michael
Last Name: Deichmann
Carburetor dilemma
Post by dykker5502 » Wed Sep 06, 2023 8:13 am
Hi,
my 1921 Model T pickup generally runs OK, but the idle is nothing to write home about. It basicly can't go idle and when stopping for red for exampe, I have to either let it idle fast or be at the throttle all the time. The carburetor is a stock Holey NH.
Now, my 1914 Model T touring have an aftermarket carburetor - a Toquet - which I am very happy for and where the idle is really smooth and slow.
I could restore the NH and probably get better results - but since the NH do not have a dedicated idle circuit in it, will I ever get the engine with the NH to go as smooth as the one with the Toquet carburetor? Or any other aftermarket as if the NH can't do it after a restore, I might as well be in the market for a new 3rd party carburetor for my pick-up.
Ford Model T 1914 Touring
Re: Carburetor dilemma
Post by Jerry VanOoteghem » Wed Sep 06, 2023 8:38 am
The NH has an idle circuit. It has to do with the 2 small holes near the throttle plate. If you remove the brass plugs and drill out the small holes in the NH I think you'll be fine. A properly working NH will allow for a very nice idle.
Post by speedytinc » Wed Sep 06, 2023 8:45 am
This may be your main issue.
A worn sloppy throttle shaft also will cause the idle speed to vary as the butterfly jiggles around.
Keeps the carb from a consistent idle fuel supply.
"A properly working NH will allow for a very nice idle."
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Wed Sep 06, 2023 10:10 am
If there's a large amount play in the shaft it'll need attention. If it's really kind of minor there's a felt ring used on lawn mower throttle shafts that will do wonders in sealing it up. I've done it. It works. As to the idle circuit passages: no need to start out with drilling. At least not at first. A can of carb spray with the thin straw nozzle on it will give you a quick indication of the passages condition. If it blows through they're either clear or it's blown out some junk. If not drilling is your only other option.
dykker5502
First Name: Michael
Post by dykker5502 » Fri Sep 08, 2023 1:33 am
OK, I'll plan for a proper full rebuild of the NH carburator then. Thanks!
