This is a Bennett brake pedal for external brakes on a 26/27 model T. There is a couple of extra holes that need to be repaired. It looks like it might need to straightened also. $ 50.00 plus the postage. Tom five03-644-937four twoelliott@msn.com. I don't think this was used as it wording Bennett in the pedal is still sharp. There is a little welding done on the shaft that can be cleaned up without too much trouble.
I should also add that this pedal does not have the cam , so it is a pedal that works the external brake only.
For Sale Bennett Brake pedal Make offer
elliott1936
Topic author - Posts: 361
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
