early fan on a 27 engine
Topic author - Posts: 35
- First Name: Doug
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 21 touring
I have not run a fan on my car ever. No problems with overheating with a Berg radiator. I have a 27 engine in my 21. However I picked up an earlier fan, that mounts on the engine not the water outlet. has anybody done this and found a way to adjust the fan belt tension, other than to replace the front cover?
Re: early fan on a 27 engine
Would be better if you re-ask your question on the main forum.
If the fan mounting arm is the later straight style, no it really should not matter. The radiators were the same size from 1924 to 1926.
