Gallivan Head Gasket
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Thu Sep 14, 2023 11:06 pm
Does anyone have a photo or a pattern of a Gallivan head gasket? When I purchased "The Flying Dutchman" Gallivan powered 1915 model t roadster I got several new overhead gaskets but not sure if they are for the Gallivan.
A photo, or drawing would be very helpful. Also have a couple of questions regarding oil pressure and routing of oil lines.
thnx
frontyboy 2ho69191949(Seattle) fax or call
pete eastwood
First Name: Pete
Last Name: Eastwood
Re: Gallivan Head Gasket
Post by pete eastwood » Fri Sep 15, 2023 12:53 am
I would think that all overhead's would take the same gasket.
The gasket doesn't know if the head has rocker arms or cams!
Post by Mark Gregush » Fri Sep 15, 2023 10:19 am
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Sep 15, 2023 10:24 am
Pete is absolutely correct. However, I suspect that your concern is that the combustion chamber is an odd shape and so requiring a special gasket, as is the case with a Roof 16 Model C. I would suspect that the Gallivan has a round combustion chamber. There is a lot more room for those giant valves when they are presented at an angle rather than straight down like a typical overhead. Isn’t there is a pic of the Gallivan combustion chamber in the Speed and Sport book…?
Post by Mark Gregush » Sat Sep 16, 2023 4:15 pm
Olsons Gaskets, right up there in Washington state.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Sun Sep 17, 2023 9:34 am
The ad in Speed and Sport shows a round chamber.
Andy
