Looking for supplier of accessory brake shoe lining.
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Post by Craig E. Luton » Sun Sep 17, 2023 7:51 pm
Back in the 60’s I bought a pair of accessory lined brake shoes to replace the cast iron ford ones. I recently purchased a pair of brake shoes like the ones I bought in the 60’s. Where do I fine brake lining for them? They are 1” wide and held on with split rivets.
Thank you in advance for the information. Craig
jab35
Last Name: Bartsch
Re: Looking for supplier of accessory brake shoe lining.
Post by jab35 » Sun Sep 17, 2023 8:52 pm
Craig:
I usually have good results with the products at McMaster-Carr. Here's two offerings in 1" wide brake lining:
https://www.mcmaster.com/products/brake ... rlayer.com
Good luck, jb
Post by TRDxB2 » Sun Sep 17, 2023 8:54 pm
These are ones for people who bought non-original style brake shoes - doesn't say much
brake shoe linings.png (26.84 KiB) Viewed 862 times
May be cheaper in the end
Post by DanTreace » Sun Sep 17, 2023 8:56 pm
Used the modern lining sold for the 26-27 big rear brake drum. The lining is woven with brass so take care in handling. It's also too wide, but riveted it on one edge and then to the bench grinder removed the overhang. Use care with gloves and good face mask and shield to prevent inhaling dust.
Used hollow brass rivets instead of the supplied split rivets. Countersunk the head and figured the more solid hollow rivets gave best security.
Craig E. Luton
First Name: Craig
Last Name: Luton
Post by Craig E. Luton » Sun Sep 17, 2023 10:33 pm
Thank you everyone, I just ordered the brake lining for my car.
Craig
