Floating transmission shafts
Topic author - Posts: 270
- First Name: Noel
- Last Name: Chicoine
I'm looking at some old posts I missed and saw the one on "23 tranny on 26 block". Is there any chance Les or somebody would consider doing another run of the floating transmission shafts. I have 2 and would like a third and maybe a fourth. I'm sold on the concept and believe they may be the best way to protect the center main, preserve our limited crankshafts for the future, and maybe protect a new Skat investment. I remember many years ago Paul Vitco doing some deflection studies while running and pressing the pedals.
- Last Name: Tannehill
Re: Floating transmission shafts
I believe Dan Hatch was licensed by Les to produce them in the USA but could be wrong.
- First Name: Les
- Last Name: Schubert
Dan has quit
I will think about it
- First Name: Joe
- Last Name: Kowalczyk
Les, I would be interested in one
Regards,
- First Name: Shannon
- Last Name: Helm
I would as well, Les.
- First Name: Tom
- Last Name: Dove
- * REQUIRED* Type and Year of Model Ts owned: 1925 Touring, 1925 parts car(?)
- Board Member Since: 2022
I'm interested as well. Will be rebuilding next spring.
Tom
Tom
I have never let my schooling interfere with my education.
Education consists mainly of what we have unlearned.
- First Name: Bryant
- Last Name: Shafer
I am interested. This seems like a product that everyone might need.
Bryant
Bryant
- First Name: Paul
- Last Name: Mikeska
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Speedster, 1923 Farm Truck, 1926 Coupe
I would buy one or more.
I believe the last two bought for customers were in the $400 plus range each. But that was pre Covid 19
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
I would be interested as well
A description of the item and advantages it offers would be helpful.
- Last Name: Hatch
Here is a link to my last batch. In the ad is a link to Les’s original post about the Floating Shaft.
https://www.mtfca.com/phpBB3/viewtopic.php?t=3480
- First Name: Les
Hopefully Dan will run another batch!!
- First Name: Les
A local guy has “converted” some original Ford shafts into the “Floating Version”. It probably reduces the cost to about half. A option to consider!
- Last Name: Hatch
Les: That is what my guy work out the kinks on, old Ford shafts. Only took him one, hate we lose him. Don’t think I will do anymore, cost too high and no one wants to do small runs of stuff. Have to do 50 and that is way too much to tie up.
The guy doing my Stevens inserts has to have close to 1000 pieces to do the job. And cost just keeps going up. I think he hopes it will run me off! Dan
- Last Name: Helm
Les, are the converted shafts machined to have the gear teeth pattern and then the outer ring made from bronze as with your design? Does the shaft need to be heat treated after machining? Thanks for your information about this!
- First Name: Les
Shanon
Your description is close. No heat treatment done
- First Name: Maurice
- Last Name: Dean
- * REQUIRED* Type and Year of Model Ts owned: 1917 Touring Car
I'D be interested
- Last Name: Helm
Les, sorry; another question about the conversion process using a Ford shaft. In that method what is the outer ring made of, steel or bronze? And the flange of the shaft is faced thinner as well?
- First Name: Les
Shanon
The outer ring is bronze and yes it is about.005” thicker than the steel “star”!
