classifieds
Topic author - Posts: 481
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
- Board Member Since: 2014
classifieds
Just wondering if I missed something. I'm having one heck of a time getting to the classified sections of the forum. All that keeps coming up are past years posts, not current posts. Is it just me?
- Last Name: van Ekeren
Re: classifieds
Working as it should in Australia.
- First Name: Austin
- Last Name: Farmer
Re: classifieds
Working fine here in Northern Illinois as well.
Re: classifieds
Well, I just can't figure out why
I can't pull it up, even googling: mtfca, classified parts Oct. 2023. Never had this problem before.
- First Name: Luke
- Last Name: P
Re: classifieds
Philip, just to check you've got the right links:
Classifieds for parts - https://www.mtfca.com/phpBB3/viewforum.php?f=5
Classifieds for vehicles - https://www.mtfca.com/phpBB3/viewforum.php?f=4
I suggest you make sure you're looking at page 1 (see the bottom RHS of the page you're on for all the page numbers) because it may be you'd been browsing older posts and your browser is returning you there. If you continue to have issues you should probably clear your browser cache.
Luke.
Luke.
Re: classifieds
You might try clearing your browsing and cache history, esp if you have not done it in a while. Sometimes old information get pulled up.
- Last Name: Tannehill
Re: classifieds
Phillip at the end of this thread you will find a drop box. If you hit the arrow it will give you a list and at the bottom is ascending or descending set as the default. You can change to the other choice & will change the direction. I’ll attach a picture to make it easier. So what ever you have as that last choice listed change it to the other choice. In this case if you changed it to descending Marks post would be at the top of the thread and yours would be at the bottom. Be sure to hit GO to set the change. See if that helps. Then you can go to the classifieds scroll all the way down to the bottom of the first page of the classifieds and try the same thing. If you’ve got old post to start with it will change it to the newest post by changing from ascending to descending or vice versa
Best John
Best John
- First Name: Gordon
- Last Name: Clayton
- * REQUIRED* Type and Year of Model Ts owned: 27 TT
Re: classifieds
I've been having trouble too
Re: classifieds
What kind of trouble?
In the header click on HOME. Click on FORUM, in the drop down click on CLASSIFIEDS.
viewforum.php?f=5
Re: classifieds
It's working OK in south central Kansas.
