What am I missing here - Kingston Y 4-ball
dykker5502
First Name: Michael
Last Name: Deichmann
Post by dykker5502 » Tue Oct 03, 2023 10:11 am
After having browsed eBay and this sites classified, it turned out that I could find one to a good price just 10 miles from home. So no need to import from US, shipping and customs fees and what have you.
But taking it apart for renovation, it seems I'm missing some parts and browsing the vendors catalogs I se not many kits for restoring Kingston Y carburators. L, L2 and L4, but not Y. However, reading various forum posts maybe I can use some of the parts for these newer Kingstons?
What is missing here in the threaded hole?
The threaded hole to the right?
Can I use a later float? I do not think this is ethanol proof
Ford Model T 1914 Touring
First Name: Keith
Last Name: Townsend
Re: What am I missing here - Kingston Y 4-ball
Post by KWTownsend » Tue Oct 03, 2023 10:26 am
A bowl drain valve fits into the threaded hole near the gas inlet. The float pictured looks like the correct style, but check that the pivot point is in the right place. It might just be camera angle, but the bowl body looks more elongated than other Kingston 4 ball carburetors.
Post by Mark Gregush » Tue Oct 03, 2023 11:02 am
Does this help? Look at page 42; http://www.cimorelli.com/mtdl/1914/default.htm
dykker5502
First Name: Michael
Post by dykker5502 » Tue Oct 03, 2023 3:48 pm
Mark, thanks, but that link just leads to a page with a lot of 1914 Ford literature. Which ofthe documents do you have in mind?
Post by Rich Eagle » Tue Oct 03, 2023 4:57 pm
Page 42.
dykker5502
First Name: Michael
Post by dykker5502 » Wed Oct 04, 2023 8:36 am
Thanks Mark! Very usefull.
I also found this post in the Classified forum with pictures. I draining petcock it is that are missing.
Post by Mark Gregush » Wed Oct 04, 2023 10:35 am
Sorry, I thought the link would take you to the parts book I was looking at. Anyway, great source of information on Model Ts. If you click on BACK TO START, it will take you to the main library.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Wed Oct 04, 2023 11:37 pm
Here is how you can make a choke spring from an NH choke spring when you get that far.
dykker5502
First Name: Michael
Post by dykker5502 » Fri Dec 22, 2023 12:42 pm
What thread size is it? 1/4" ?? 1/8 pipe?
Post by Mark Gregush » Fri Dec 22, 2023 3:53 pm
1/8 inch pipe thread
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Dec 22, 2023 7:02 pm
Some are 1/16" pipe.
Real itty bitty.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Dec 22, 2023 7:03 pm
Real itty bitty.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Fri Dec 22, 2023 8:02 pm
It’d really be a nice find if you could actually locate the drain valve as pictured in the parts photo. Lots of broken ones because people forced them to open. The handle is very petite. Most of the time the needle & seat on the 4 ball leaked like a sieve. I believe Corey Walker does a very nice job in making that problem go away.
dykker5502
First Name: Michael
Post by dykker5502 » Fri Dec 29, 2023 7:01 pm
I ordered a 1/8" petcock from Langs and received today - it's to big, so i buy that it's 1/16" pipe thread. Hm. I'll check with the local "pushers" what they have lying around...
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat Dec 30, 2023 6:57 pm
Michael-
In the mean time, you could use a 1/8" to 1/16" pipe adapter...
Here is one that will fit, but not original:
https://www.deboltmachine.com/collectio ... rain-valve
1-16 pipe drain valve.jpg (11.3 KiB) Viewed 3756 times
Keith
Mark Anderson
Last Name: Anderson
Post by Mark Anderson » Sun Dec 31, 2023 12:38 pm
The float looks like one similar to a Linkert Indian/Harley Davidson float. The Float arm is similar to one used on the DX304 carb and also used on the DLTX #3 used on early John Deere model D and also used Hart-Parr tractors.
dykker5502
First Name: Michael
Post by dykker5502 » Mon Jan 01, 2024 1:47 pm
I've bought a L2 float of modern material which I believe can be adapted for use in the L4 carburator.
dykker5502
First Name: Michael
Post by dykker5502 » Tue Jan 02, 2024 12:28 pm
It turns out the 1/16" petcocks seems to be made of unobtanium, so now I have purchased a simple 1/16" NPT plug to just close the hole so I can get the carburator assembled and get the engine started again.
